Water pressure gauge is reading higher than normal
I have a 2005 Sabre with an XR6. It seems to get better water pressure with a Fury and no plugs, than a medium sized plugs in a Tempest. Problem is it seems to be reading too high now. Im used to around 13-14 psi at WOT but its ready almost 20. When I take off its over 25 and thats not right. Anyone had this happen before ? Should I disconnect the line at both ends and blow air through it ? I never get sprayed under the dash with water so I dont want to mess anything up with the connection if possible. Thanks.2005 Sabre, 150 XR6, Minn Kota Fortrex with Lowrance electronics
Home Forums Bass Cat Boats Water pressure gauge is reading higher than normal
