Deadonjohn wrote:Thanks for the replies. This boat had a previous owner and I took it to the shop to get my graphs installed so I have no idea what they did previously. It does look like a hot wire connected to two grounds. Ill have to trace them back and see whats going on there. MeanV2, thats what I figured but wanted to see where I can hook my ground into. I figured those wires were ground wires. Ill just splice into a known ground thenThat is a mess that needs to be addressed and sorted. Looks like previous owner didnt have one color wire, so he picked and chose from what he had. Also, as mentioned above, the twist wire nuts are not appropriate in a boat/water environment. As to finding a ground wire, a voltmeter is your friend. Place the red lead on a good hot and probe the black leads. When you get 12V you should be OK.JohnJones Trolling Motor Services870 773 3474Motorguide/MinnKota/PowerPole/Lowrance/Humminbird
