Fairly common occurrence. Not a manufacturer defect. The white pigment in the gelcoat will eventually “yellow” or fade. Depending on how bad it is or how much it bothers you, I think I have read where it could be improved with a rubbing compound or if really bad, wet sanded gently. Would have to check with BCB on that. I had a white top cap boat and it did show some signs of fading/yellowing about 9 yrs after I bought it. Good luck. I tried to search FAQ section but to no avail to help you………Last edited by jignpig on May 21st, 2009, 2:47 am, edited 1 time in total.96 Eyra/12 Mercury 175 Pro XS with 2015 single axle trailer2017 Victory Gunner
