Yamaha oil pump replacement
In case you havent seen or heard Yamaha is replacing the oil pumps on most of their 150HP and up outboards built since 2004. This will give you most of the info that is out so far. There is a service bulletin out on the problem plus Yamaha seems to be taking care of the problem even if the motor is out of warranty. bbcboards.zeroforum.com/z...?id=209761Johnny
Home Forums Bass Cat Boats Yamaha oil pump replacement
