This is usually not the actual sending unit, though it is often only the top capsule on this model. The sending units are usually pretty durable, and we would replace is with the same if it failed. Though try to get just the top plastic capsule and replace that first. You may also be able to reverse the two right and left capsules and test the opposing sender that way. Since you have two (2) fuel tanks in a P2 model. BCB
