where is it safe to put screws in the aft compartment
I am in the process of starting a total electronics upgrade on my 2008 Puma. I am also upgrading the batteries to Lithium..Currently I am running 4 group 31 AGM;s.. With the change to lithiums I am going to need to reconfigure the aft battery compartment. The previous owner did some reconfiguration already to make room for the power pole pumps.  I cannot tell you what he moved and where as i am not familiar with how it was configured from the factory..My question is where, if at all is it safe to put screws in the floor to secure the battery trays? Also, where is it safe to put screws in the transom to secure the battery charger? The current charger is mounted to the transom already, but i cannot reuse the existing holes for the new charger..The last thing I want to do is inadvertently put a screw through the hull...Any advise would be appreciated..
Home Forums Bass Cat Boats where is it safe to put screws in the aft compartment
