24 Puma STS wiring question – master power switch
Is an additional power switch or resettable breaker needed on the house battery if the battery is used only for starting, jack plate, A-10 touch pad, and PPs (PPs have their own breaker) - would the master power switch near the driver seat suffice?  Is there any power draw when the master power switch near the driver is turned off, and if so what would it be? I have dedicated electronic battery with its own breaker so the electronics shouldn't be factored into the discussion. Thanks.
Home Forums Bass Cat Boats 24 Puma STS wiring question – master power switch
