Looking for Livewell System Diagram – 2023 Eyra
I’m hoping someone here — maybe even someone from Bass Cat — can help shed some light on the premium live well system design on my 2023 Eyra. Recently, the live well valve on my rig malfunctioned, and while the local dealership is in the process of replacing it, digging into the system has raised a few questions I can’t quite wrap my head around. Here’s what I’m seeing: The aerator pump is connected to the side of the valve, which I understand is standard. When the valve is in “Auto” mode, it seems to hold water in the live well, while still allowing fresh water from the lake to be pulled in and circulated. That part makes sense to me. However, I’ve noticed that even when the boat is out of the water and the live well is still full, I can turn on the aerator and water is still pumped into the well. This has me scratching my head. How is the system still pushing water in when there's no external source (i.e., the lake) to draw from? Is it recirculating internally through a separate loop? Or is there a check valve or bypass somewhere I’m not seeing? I think if I had a diagram or schematic showing the full layout of the pumps, valves, and plumbing, it would really help clarify how everything functions — especially in and out of water and in different modes (Auto, Recirc, Aerator, Empty, etc.). If anyone has access to one, or if Bass Cat support can weigh in, I’d really appreciate it! Thanks in advance, Greg
Home Forums Bass Cat Boats Looking for Livewell System Diagram – 2023 Eyra
