Greg, when the aerator is on, it is pulling water from the lake and recirculating the water in the livewell at the same time. The first image is empty mode. the second image is recirculating water. the third image is aerating mode.
BassCat Livewell System Explanation
AUTO – OFF-PLANE
Once the first fish is caught, simply place the rotary actuator in the “AUTO” position, turn on the aerator pump and forget it. With the boat off plane, fresh water will be constantly blended with recirculated livewell water. This ensures a properly filled and freshened livewell at all times and that any ammonia laden used water is expelled through the overflow.
AUTO – ON-PLANE
When the boat is placed on plane, the control valve will automatically close the transom port to prevent water loss and the aerator pump is automatically diverted to closed recirculation duty. When the next fishing spot is reached and the boat is brought off plane, the control valve automatically opens the transom port to again allow fresh oxygenated water to be added to the livewell. Therefore, any water that was lost through the overflow while running from spot to spot is automatically made up without any operator assistance.
EMPTY – ON/OFF-PLANE
The “EMPTY” position is, of course, used for draining the livewell. It is, however, much more than just an open drain position. When placed in the “EMPTY” position, the control valve allows water to exit the transom drain, but not enter. This check feature is most appreciated by the tournament angler, who in the wee hours of the morning, does not have to remember to close a livewell drain prior to launching as the control is already in the “EMPTY” position. Water will automatically be prevented from entering the livewell as the boat is backed into the water. No more blast-offs with hundreds of pounds of unwanted water in the livewell.
This reply was modified 10 months, 3 weeks ago by
JEH in La.
