92 Pantera Classic Prop and engine height
I recently bought a 92 Pantera with a 2020 Mercury 200 fourstroke V8. It came with a Fury 3 22p and at the moment I'm just able to get it up to 5600 rpm which gets me about 60-63mph. That's with the motor at 4in p2p. A couple friends who run jaguar and eyra love 4 blade props and I was thinking I might like that as well, I tested some 4 blades they had, fury 4 26 and Trophy 25, but both of these I could barely get to 5000. So I'm guessing if I wanted to run a 4 I'd probably need a 23 or so pitch. I've also tried the motor up a bit at 3.5 ptp with the fury 3 and it starts to blow out and didn't gain any rpm. Reading around it seems like this setup would be an easy 70mph boat and I was curious if that sounds reasonable, and if my setup, prop and motor height, seems optimal for this boat.
Home Forums Bass Cat Boats 92 Pantera Classic Prop and engine height
