Dont know if you plan on intalling another unit or not theres a pic of my console on my 11 puma in my profile, i went from a hds 10 to hds 9 touch and used aluminum plate to cover the gaps. If you arent installing another unit a piece of carbon fiber with adhesive backing could work too. Be alot cheaper than a new console or fiberglass work. Another option could be to make a bracket to go behind the console then bolt the exterior cover to it similar to how your gauges are held in place. Good luck
