I am not sure how your Verado or opti max is set up, But the Manual adjustment screw that you loosen to lift your motor by hand when your trim unit fails(or your 20 amp fuse blows ) is made out of plastic, well it is imperative that you have a screwdriver that will fit that slot exactly, the larger the better. That day at the ramp we had one that was about 1/8″ short on both sides and it tore the head of the screw all to pieces. So today I got to spend about 2 hours with a drill, drill bits, a tap to rethread the damn thing and a whole lot of sweat, not to mention that damn little plastic screw cost 44 dollars! Thsi design is just plain dumb, they can make the same design out of an aluminum or S/S screw and this would not be a problem. Also listen when the manual says to only turn three times to relive the pressure of the unit. So if your Verado/Opti has the same little adjustment screw I would advise you to pack a screwdriver that fits that slot exactly.This was on 06 200 OptiJay Law
