Anyone running a Garmin LiveScope?
Hey guys, recently mounted my Garmin Livescope transducer on 2020 Eyra.  I put in on my Ultrex and for those of you that haven't tried it....it's amazing !!!  Now, I do have a question for anyone who has mounted and run this system.   We found the best image to be with the transducer mounted on the Left side of the Ultrex downtube/shaft.  But that requires spinning the TM head around so the prop is on the Left of the boat.  This also means that you have to re-route the HB transducer cable to the L side also to keep it off the plastic guide ramp on the front of the Ultrex.  ie....it's just a bad condition for the TM head to be in.   So, anyone running the Livescope transducer on the R side of the down tube?  Did you have to configure the program/unit to flip the image with the transducer reversed?   thanks in advance !!!
Home Forums Bass Cat Boats Anyone running a Garmin LiveScope?
