Home › Forums › Bass Cat Boats › Back up light not working
One of my back up lights is not working. It was working fine till today. Does the entire glass piece inside the rubber need replaced?
If the light is bad you can buy a new one at a tractor store since they are tractor headlights. Just a FYI.
Very easy to pop out and replace. Takes a Wagner Halogeno H-9414 Sealed Beam 12 voltI have found out it works the best to take the entire light off trailer when replacing the light.Ron
Thanks guys. Is water prone to getting in these lights? Not sure why this would of went bad so quick.
They are usually not an item that goes bad from what I have seen. Have you checked your connections to make sure they are all good?
We loose more than the factory likes, though not too many when the cost and replacement is considered.
OReilly auto parts has that light for about $19.00. That was the cheapest price I could find.
