I use TS321 on Bearings, line guide pawl and shaft, spoil shaft- brake shoes- use a quip and put a film of oil on metal surface on side plate that brake shoes would rub on. Very light coat of grease on entire surface of the body area inside of reel with the gears. – and the components inside- make sure main gear and pinion have a nice even coat on teeth. The drag disk get shimano drag grease or Cals. Even the carbon disk get the drag grease( they work way better). The knobs get a drag grease/and oil film on shaft- oil on the bearings or bushings
