Batteries question 31MDC, Exide Nautilus Marine & RV Deep Cycle Battery not trying to beat a dead horse LOL
Below is a link to a page that list these. It is not the place Ill be buying. I can get these for about $115.00 each. Looking to replace the interstate 27s I have. they are at least 5 years old. Would there be a reason to not use one as a cranking battery? All my electronics and livewells are hooked up the the cranking battery so I do not want to run it down. The current Interstate 27 is a Deep Cycle used as a cranking battery with no issues. Based on the specs it sounds like a great deal. Menards can special order them so they should be new and if I time it right I might get an additional 11% off. Also these will be going into a 98 Sabre with a Merc 150EFI. The 27s are a pretty tight fit. Is there a big difference in footprint? I want to stay with a flooded battery.So anyone ever used them??Here are the specs:Cold Cranking Amps (CCA) @ 0°F, 725, ||Marine Cranking Amps (MCA) @ 32°F, 900, ||Reserve Capacity Minutes @ 25A, 205, ||Amp Hours (20 Hr Rate), 115, ||The weight is as at least 70 poundshttp://www.labatteries.com/shoponline/i ... uct_id=601
Home Forums Bass Cat Boats Batteries question 31MDC, Exide Nautilus Marine & RV Deep Cycle Battery not trying to beat a dead horse LOL
