Home › Forums › Bass Cat Boats › Bow Electronics Wiring
Where does the power come from for the bow electronics? I believe they were installed at the factory. Do they go through the rod locker and then back the entire way to the terminal panel that is on the transom? I have a 2012 PII. Any help would be appreciated, trying to track down a problem.
they should run in the right hand (Starboard) gunnel and some inside the PVC. Grounds go into a 4 way start connector at the console and distribute from there after leaving the Terminal Block on the transom. BCB
Bass Cat Boats wrote:they should run in the right hand (Starboard) gunnel and some inside the PVC. Grounds go into a 4 way start connector at the console and distribute from there after leaving the Terminal Block on the transom.BCBi cant find the 4 way start connector, what does it look like and where are they usually located in an 11 PII?
It is a Star 4 way splitter. There will be four yellow connections with one rivet holding them together. This should be tucked inside the console gunnel area.
downislandliving wrote:Where does the power come from for the bow electronics? I believe they were installed at the factory. Do they go through the rod locker and then back the entire way to the terminal panel that is on the transom? I have a 2012 PII. Any help would be appreciated, trying to track down a problem. Sounds like you are working to wire front electronics direct to battery to eliminate voltage loss. I am working the same issue to run a large wire to the front from one of the TM batteries to reduce the draw on the cranking battery.
BamaCat wrote:downislandliving wrote:Where does the power come from for the bow electronics? I believe they were installed at the factory. Do they go through the rod locker and then back the entire way to the terminal panel that is on the transom? I have a 2012 PII. Any help would be appreciated, trying to track down a problem. Sounds like you are working to wire front electronics direct to battery to eliminate voltage loss. I am working the same issue to run a large wire to the front from one of the TM batteries to reduce the draw on the cranking battery. that is something i am thinking about, i am going to try to find Star 4 way splitter and clean those connections tonight.
© 2024 Bass Cat Boats
