easy view tackle system?
Are there any of you out there using this tackle system under your compartment lids? If so Im curious as to how you installed it. I dont want to screw into the lids beside maybe where the Rib is I guess. But the underside of my 2011 Puma Ftd has a thin foam coating under the lid. The other method to mount this system is with adhesive and Im not so sure that would work well on that foam padding. Any thoughts or pics of yours installed? Heres the link to the easy view system Im thinking of going with. https://www.easyviewtackle.com/index.html. I have in the past owned the Cooks System and really liked it. I may still get a couple of those as well, but still the same question about mounting it to the foam.Thanks in advance for any suggestion or advice.
Home Forums Bass Cat Boats easy view tackle system?
