Home › Forums › Bass Cat Boats › fury prop 0n 07 puma
has any one run a 26 fury on 07 puma yet and would it be better than the 26 trophy i have a 250 pro xs
There have been several that have tried them not sure but I think they have been on the Cougar and the Puma. The best that I can remember they are seeing better results from Fury, holeshot and topend by about 2 or 3 mph. Phil A. I know tried one and think was impressed with the numbers he put up. There will be several that will post on this topic. Overall the numbers are from everyone that I been hearing from. My only concern is getting it worked on repaired. Might want to check or someone may already know that answer. One more thing I believe that PA runs a Trophy 26. Good Luck! Robbie
I ran a 26 Fury on my 08 Puma and it ran about the same top end wise as my two best props (28 Trophys). The difference was in holeshot and acceleration. The Trophy props handle better (less driver input) and are probably better props in very rough water, but the Fury is still a good prop. Without knowing what youre carrying, where youre driving, or what youre trying to achieve makes it a little difficult to tell you its better than what you have.
PhilAddison wrote: I ran a 26 Fury on my 08 Puma and it ran about the same top end wise as my two best props (28 Trophys). The difference was in holeshot and acceleration. The Trophy props handle better (less driver input) and are probably better props in very rough water, but the Fury is still a good prop. Without knowing what youre carrying, where youre driving, or what youre trying to achieve makes it a little difficult to tell you its better than what you have. I only got to run one for about 15 minutes before some called wanting it to try so I gave it up but from what little bit I have run it I would agree with that 100%. For day in and day out running I am really starting to like the 26 Trophy even though I gave up a little bit on top end over the 27 Trophy. For anyone who is just learning to drive a boat that carries these speeds the Trophys are the better props over the Tempest or the Fury. My 2 cents… Judd Lasiter
Overall that would be correct, though dont forget we found one that liked a Tempest also. Only one, though we did find one!
thanks for the help i think i will stick with my trophy
© 2024 Bass Cat Boats
