The Oil section doubles as a heat alarm. Check that for a solid bar, and that flashes when you turn the ignition key off, and turns out when the key is on. It will flash when it’s low on oil or has an oil pump issue, the solid segment window is heat. When it goes solid the engine is coding heat.
