Ignition Switch or Starter Solenoid
2008 Optimax Pro XS 250hp -300 hours - never a hitch - spring start up fired right up 1st time - stored inside always, heavily serviced, fogged, gas removed each year, gas additives always, greased, lower unit service couple times a year - new outer shaft seals this year - runs perfectly - just started only firing when you are releasing the key - won't fire if you just keep holding it on. Subsequent times the fire up is only when you release the key, it just keeps turning over if you hold it. I am leaning toward a new starter solenoid but has anyone had this issue? What was your experience? Thanks
Home Forums Bass Cat Boats Ignition Switch or Starter Solenoid
