Im seriously considering adding a shallow water anchor to my 2011 Sabre FTD, after all, its only money right? lol! Anyways Ive spent the last few days researching both the Talon and the Power Pole options. At first I was pretty set on the Talon…especially because of the form factor of the new 3 stage 8 but the more Ive looked at the Power Pole, the more I start to swing in that direction. Particularly when I compare cost between a Talon and either a Sportsman 2 or Pro Series 2..if, for example, I went with the Sportsman 2, I could get a dual set up, for not a whole lot more than the single Talon with bracket. The Sportsman 2 is also the lighter option…27lbs + bracket (say 10lbs?) putting it at around 37lbs. Thats roughly the weight of just the Talon; add in the 20lbs of the Talon bracket, and youre at 57lbs. With my 150, Im leaning toward keeping it as light as possible.So, a few questions:- How much would an 8 Power Pole ride above my motor in say, level position? (I have a “dog box” for the back of my boat in the garage, and would need to be able to clear its height for storage)- How big of an impact do you think the weight savings (over a Talon) would be on holeshot and top speed?- Everything Ive read seems to give the Sportsman 2 good reviews and PP lists it as having the quietiest motor…apart from finish and warranty, any huge reason to step up to the Pro Series?-Prices Ive tracked down:8 Talon + bracket + remotes + footswitch=$18758 Sportsman + bracket + remotes = $1245/single braced bracket or $1360/dual braced bracket8 Pro Series + bracket + remotes = $1490/single braced bracket or $1605/dual braced bracketIf I went with the Power Pole, Id likely lean toward the Sportsman 2…if I went with the single braced, Id be sorely tempted to bite the bullet and get 2 of them. Is the dual braced a must? If so, Id probably do just get one this year and another down the road.Finally, I do like that the Power Poles are made in the US…cant track down where the Talons are made…Im sure Ill have more questions as I continue thinking about this, but many thanks for any insights to get me started! 2011 Sabre FTD w/ Mercury 150 Pro XS, Power Pole Sportsman 2s, Humminbird 898 w/ 360 and 858 at bow, 898 at ConsoleFor lots of BCB love, follow me on instagram: @professorbeard
