Question for Basscat regarding trolling motor plug wiring:
Pretty sure the plug receptacle is wired at the factory. Can you tell me why on the 4-prong plug, BassCat uses the terminals that would normally be the 12V wiring. The terminals used are Battery A positive and Battery A negative. This puts the "slots" for the plug as the "L" shaped (for the ground) and the one immediately next to it in a clockwise rotation for the positive feed. The plug, when wired to match the receptacle, uses the "ground" connection and the "12V" connection instead of the "24V" connection. Its no biggee as any of the prongs/terminals can carry the voltage needed for the trolling motor so it doesnt effect the trolling motor or the batteries. However, for us that do service work on trolling motors and have our benches rigged with the 4 prong plug receptacle for testing, we have to undo and rewire to each Basscat plug to get the universally correct configuration. Just curious as to if there was a reason.JohnJones Trolling Motor Services870 773 3474Motorguide/MinnKota/PowerPole/Lowrance/Humminbird
Home Forums Bass Cat Boats Question for Basscat regarding trolling motor plug wiring:
