I’ve got a 2008 P2 that I’m thinking of swapping trolling AGM’s for Lithium. I currently am running the group 31 Duracell AGM’s (105 AH I think) you can get at Sams for a 36 volt 112 minn kota. Those suckers weigh over 80lbs a piece, so you can imagine my P2 is butt heavy with three of those plus a starting battery, plus two pro-series power poles. There’s a third fat guy on back of boat every trip! It’s time (again) to replace these and I want to swap out the three trolling batteries for three of the Relion 100AH (about $930 each right now). Mostly for weight but also seems to make sense from a long-term cost perspective. Those weigh in at about 30 lbs each, so I could shed 150lbs+. My question is…do you think the 100AH batteries are way overkill? I could cut another 15lbs out of each battery if I went with the 50AH. I fish alot of current (which is why I have the 36 volt in first place) so my gut tells me to go with the 100AH, but I have read posts that say the 50AH are more than enough. Also, what kind of charger? I gave up on onboard chargers awhile ago but thinking of just getting a dual pro and not mounting in boat. Can’t really find a good alternative charger that I could just keep at house. Also, thoughts/experience here with brands, etc. appreciated.
For those wondering my boat has 2008 200 HPDI (stock yamaha three blade prop) and currently runs about 69 MPH with this setup and two 200lb guys and gear. When I got the boat, no power poles, motorguide 24 volt TM, three group 27 batteries (including starter) it would run about 74-75ish.
