Tireman I would not be pulling those poles off yet, at least not before you run the boat empty, etc. Let me give you an example, prior to this boat I owned a 2013 Cougar FTD, 250 Merc, no power poles. Almost identical to the Cougar AE I am currently running, top cap layout is a little different and I lost some of the bells and whistles but the main thing was the year of the motor, and no power poles. That boat I drove it above 77+ mph, no fighting the wheel as I gained more speed, nothing. The boat drove at speed rock solid. It had a stock 26p fury on it for a prop, same manual jack plate, etc. That boat just ran, came out of the hole, it was good. Now this boat, I am running a 25p fury that has been worked on and the boat wants to dance with me starting around 68-70. It drives me nuts that I can not drive this thing as well as the other boat. I even took it back to the dealer, both tanks full of fuel (52 gallons), 4 batteries, about 20 rods, more 3700 boxes full of whatever than I care to count, an anchor and yes 2 guys in it with a combined weight probably over 525. The guy that was driving took my boat from zero to over 77 and it was still climbing when he asked me if it was fast enough. I said yes, and realized then I really don’t have a clue when driving these boats at higher speeds. So don’t feel alone in that camp, and I have had cats for over 10 years. Keep on driving it, finding someone that is close (if your dealer is close I would start right there) who knows how to drive and set these boats up. It is close when you get it from the factory, all you have to do is get it loaded right, and go from there. Good luck.
