Torsion Axle issues
I have a 2013 P2, with a Tandon Trailer (purchased 8/2014) and the splines/teeth on the Torsion Axles and Arms (all 4) are worn causing the Arms to rotate down and the tires to rub on the fenders and bottom out. The pictures show how much the teeth have been worn down, even thought I have checked to maintain 150lb torque on the arms. The rusting of both components seems to have contributed to the problem as you can see in the attached photos ( before and after cleaning). Should there be some type of grease or coating to prevent the rust issue? Is this a common typical problem with torsion axles to need to replace everything every 4-5 years? The Dealer I purchased the boat from changed out the Arms in 2018 (warranty issue) because of side to side play in the wheels/arms, but not the axles and I don’t know what the condition of the axles were at the time, so I don’t know if that was part of the current issue. thanks for any feed back.
Home Forums Bass Cat Boats Torsion Axle issues
