I’ve had major cracks in a previous swing away tongue before on older cat trailers. Just a couple of questions and again, just speaking from previous experience as I had to replace the pivot bracket 2 times, the last one being the biggest pivot bracket I’d ever seen them build.
When you store your trailer, do you keep it pinned and under tension? Or pinned and strap loosened? Or swing away engaged and strap loosened?
With all of these scenarios, have you considered or do you support the tongue extension closest to the vehicle with any additional support? With swing away engaged, and turned to the side, that weight may be twisting the single bolt ever so slightly.
Just some thoughts from someone who’s seen cracks like those before. Good luck!
