Water Leak Passenger Seat Compartment
My 2019 Eyra passenger seat compartment has had a water leak from the first day I owned the boat and was out in the rain or washing the boat. The dealer put sealer on the 2 screws that holds the seat frame to the boat. Still leaks water into the compartment ruining whatever is in the compartment. So I removed everything and placed brown paper in there and poured water around the seat. I checked for leaks and by the pictures of the paper the leak appears to be at each bend of the gasket at the rear of the seat. Further checking the source of the leaks the water leak is at where the gasket fits the cutout contour to the fiberglass like the cut out is slightly larger than the gasket or the gasket is smaller allowing water to leak in under the gasket into the compartment. The drivers side is dry never gets any water in it. Wondering if a new gasket may fix the leak or I would someone have an idea how to properly fix this leak because anything I put in that compartment will get wet and will mildew if I don't remove the items and dry it out.
Home Forums Bass Cat Boats Water Leak Passenger Seat Compartment
Viewing 12 posts - 1 through 12 (of 12 total)
