I was bleeding my trailer brakes the other night, and low and behold when I got started I pushed on the release bracket and the whole thing came out. This is part 34378 from UFP. I’ve spent literally two hours trying to get this and the spring (part 32546) re-assembled with no luck. I’ve called USP/Dexter and spoke to 3 people, none of which could tell me how to re-assemble. Then they asked me to call one of their distributors and they had no idea either. I was pretty surprised, but apparently between their operations in TN and CA, nobody has a clue how it goes back in there. I’ve looked over the net and found a couple of folks that have had same issue, but no info on how to replace it.
So I turn to you guys. If anyone has any ideas I’d appreciate it. The trailer still functions, thought the release brake will not…over 2 parts that cost about $5 to replace.
My next step is to disassemble the actuator and see if it helps, the problem is unless you have the hand size of a 5-yr old there is no way to get into the area these parts ago. Not to mention I have no idea how they came loose to start with. If I can get the spring back in I may have a chance but no clue how it’s supposed to be oriented with the bracket.
